Gene&Mary
I have a 2005 22' C Dory. I noticed some hairline cracks in top edge of the transom on either side of the transom where it curves from horizontal to vertical. Looking from the top, the transom is ~1 1/2" thick. The cracks are on the boat side of the transom thickness and at either side of the transom. It looks like the cracks are ~3-4" long along the horizontal and are not on the vertical. Hope my description of the location is good enough.
Questions-
1. What material is sandwiched between the front and back faces of the transom panel. Is it foam or something harder like wood?
2. The attachment for the motor isn't visiible from the boat so I assume it is in this space????
3. I would say the cracks were there for a while before I noticed them. Any problem using the boat until I can get it to the shop?
4. Anyone seen this problem before?
Questions-
