I like the cost/benefit point, and also just the point that it's good to think about things from various angles.
ShellBack":2ttbghwy said:
A question though, when I was waxing up close I noticed around the exhaust vent for the Wallace that there was some cracking in the Gel Coat. Hmmmm??
Can you describe it more - or even better, post a photo? Was it, say, two or three single cracklets radiating out from where fasteners might be (so, like individual sun rays at, for example, "3, 8, and 11 O'clock"), or was it cracks that look sort of like parentheses enclosing the fitting, or...?
If it's the "sun ray" type of cracks, those are often caused by the installer (for any piece of hardware, not just this one) drilling tight clearance holes for the fasteners, and then not chamfering them at the top. Then when said fasteners are tightened you often get "sun ray" cracks radiating out from them.
That said, regular thru hulls don't usually have individual fasteners, but are more like big (hollow) machine screws themselves, with a retaining ring on the inside where a regular nut would be on a regular screw. I suppose if the clearance hole were really tight then maybe the through hull body could make sun ray cracks, but that's not something I've seen. (I guess I had better go look at how the Wallas through hull is installed.)
If it's the "parenthesis" cracks, then that may have been caused by pressure right on the through hull - say someone hit a dock just right (erm... make that "just wrong") and the through hull had a good bit of inward thrust put on it - well, then I could imagine parenthesis cracks forming around it.
As you can tell, seeing how the cracks look is a good clue to how and why they might have happened.
