Well-known member
- Joined
- Nov 7, 2003
- Messages
- 7,984
- Reaction score
- 26
- C Dory Year
- 1984
- C Dory Model
- 27 Cruiser
- Hull Identification Number
- wn something
- Vessel Name
- to be decided later
Hi, This is really a general question on rebuilding decks as the boat in question is a non-cdory, but I wanted the advice of the many talented / gifted boat builder, repair experts here on the pub. So now that the a$$ kissing is out of the way here's the problem.
So my fathers 44 Atlantic has some rot in the forward deck. Seems that the windless, which was mounted thru the bow pulpit then thru the deck, leaked and has caused a large area of rot. None of the thru deck holes where over drilled and back filled with epoxy. The deck is your typical fiberglass sandwich with a balsa wood cord in between. We have cut several large holes ( 1 inch to 8 inch) to expose the rotten wood and dig out much of it. It has been drying for a few weeks now while dad has been rebuilding the bow pulpit in my garage. Turned into project in and of its self.
So the accepted way of fixing this problem is to cut out the top of the deck skin over the affected area, which is going to end up being a area of 4 to 6 square ft, digging up the rotten wood and then replacing the balsa followed by re-glassing the skin back in place. My question is this. With the 6ft cable camera my father has and some long rods we should be able to dig out all the rotten wood with out cutting out the deck any more then we have already. This would just leave the job of filling the void, which is the meat of my question. Would it be a good idea to fill the void of several square feet with some thing other them balsa core. I ask because when I had the raised deck added to my 22 ( which made it look like a newer model) they filled the space between the decks with A,B foam. I was wandering if this would be a doable project ? what are the plus and minuses of using two part foam? or even using one of the house hold construction type foams found at home depot? I wonder if the foam would provide the support needed to walk on? I don't think their is much strength in the wood core as there is in the design of fiberglass sandwich around it.
So good idea ? bad idea? Off my rocker again? lets hear it.
