Active member
- Joined
- Nov 21, 2004
- Messages
- 5,934
- Reaction score
- 7
- C Dory Year
- 2008
- C Dory Model
- 255 Tomcat
- Vessel Name
- Meant to be
All,
As I'm working on adding ventilation to the tomcat, I've also been looking into dehumidifiers. I've seen a few basic types
1) the saucer like units (or similar) which appear to be simply small heater/air circulators but which don't really remove water.
2) stick like heaters with the same properties as (1).
3) true dehumidifiers that run the air over cold coils, condense the water into a container (or out a drain) and
4) Various chemical dehumidifiers (usually using calcium chloride) in which the water is absorbed into a salt that is then disposed of.
For long term use in a humid environment, the only kind that make much sense to me is (3). Hence, for this winter I've ordered an household dehumidifier that I will set on the counter of the boat and have it drain into the sink. Are there marine units that are available which could be installed on a wall or in ventilated cabinet that are not huge? All I've seen at fairly large units that are appropriate for a much larger boat than a tomcat OR some tiny thermocouple cooled units that according to the reviews I've read are fairly ineffective. Anyone have any recommendations?
