C-Wolfe
Active member
- Joined
- Sep 16, 2020
- Messages
- 408
- Reaction score
- 29
- Location
- Anchorage
- C Dory Year
- 2008
- C Dory Model
- 255 Tomcat
- Vessel Name
- Callisto
I’ll be installing a forced air diesel heater inside the galley cabinet and debating about where to install the exhaust port. I have a Wallas stove with the exhaust port right below it, just above the waterline, very similar to my previous 22 cruiser. I had in a few rare occasions, in both the current and previous boat, got some back drafting of the exhaust inside the cabin. It happened while underway with some good wave actions, water will be temporarily blocking the exhaust port forcing it to leak where it can, inside the cabin. It doesn't last long but it does get quite stinky inside, I normally just shut it down when this happens.
In an effort to avoid this, I’d like to install it much higher, the best location I can come up with is high between the side windows, that will have the pipe running in the forward corner of the head compartment. I’m also hoping that will radiate a bit of heat inside the head as a bonus. I’m planing to increase the size of the pipe a bit to reduce flow restriction of a smaller pipe. A good portion of it will be going straight up, I’m not sure if the stack effect will be helping it enough to be noticeable. I will also be adding heat shield to any nearby material.
I don’t really see where that approach will create any issues, but if if I’m missing something, please let me know.
