matt_unique
- Joined
- Feb 27, 2007
- Messages
- 1,881
- Reaction score
- 0
- C Dory Year
- 2007
- C Dory Model
- 255 Tomcat
- Vessel Name
- Napoleon
I began the process of replacing my steering system today. Teleflex completely replaced my steering system (helm pump and two rams) with a beefier model.
So far everything is going very well. I replaced the helm pump with no problem and one of the rams. (I ran out of daylight for ram #2).
I was unable to remove the steering wheel. I removed the nylock nut so I see nothing but shaft at this point. The steering wheel should just slide off the shaft and pin. I put the bottom of the old helm pump in a vice and tried to bump it off with my hands. With no luck I pulled out the rubber mallet and really hit it hard while rotating the wheel a few inches between every hit - still nothing. I'm afraid heavier artillery may break it.
Am I missing something here? The wheel was removed less than two years ago when the last helm pump failed.
Thanks for the suggestions.
