Double-checking My Planned but Minimal Battery Upgrade
DaveInRI
Member
Aug 5, 2024
129
14
Location
Narragansett Bay
2005
22 Cruiser
Hull Identification Number
CDO22275K405
Once
I'm replacing my 6hp gas kicker with an EP Carry electric outboard, ordered just yestearday. This is basically a 270W highly efficient motor (motor/gear/prop/no seals = efficiency max), which matches a Torqueedo 603 in terms of propulsive power but using half the energy to do so, and with all the range you can choose to pay for.
My new-to-me 2005 22 Cruiser has 2005 electronics (VHF, Chartplotter, and fish/depth) which I'm replacing this spring. All 12V, and I don't want to run new wiring apart from the battery end and new electronics connectors, so I'll use a 12V lithium house battery. I'll keep the lead acid starter battery, but isolate it except for starting purposes-- the alternator will go to the house battery w/ an intermediary like an Orion in between to preserve battery and alternator. I'd then use a DC-DC connector to occasionally top-off the lead acid, if it needs it between trickle charges at home. The large 12V house battery will also have an MPPT that will be used to charge my EP Carry's portable dinghy battery when I get back to the CDory (it can also be charged at home). I am not addressing on-board inverters, solar, or shore power now, none of which are presently hooked-up or 2026 projects.
Does anyone see anything wrong with this? I'm going for 80/20 least in/most out in terms of weight savings and amp hours gained. I'd have off switches and fuses in the right requirements and locations.
Three batteries:
  1. Lead acid starter — one job only, starts the Honda. Completely isolated from the alternator and from the rest of the system. Kept healthy via occasional top-up from the house bank and a trickle charger at the home dock/driveway. Cheap and tested.
  2. 12V lithium house bank — powers everything aboard: lights, electronics, bilge pump, and the EP Carry kicker via the add'l 12V booster and cord I bought from EP Carry. The booster steps up to 24V with what I figure is 90% efficiency, which is acceptable to me in this use case. No loss of propulsive power per EP Carry (Could also use 36V).
  3. 24V lithium dinghy battery — dedicated to the dinghy when using the EP Carry on it (no booster required; native 24, have cord from EP Carry for this, too). Leaves the boat every time the dinghy does, plugs back in on return to recharge (or just taken into my house and plugged in). Could be used as backup for the CDory (kicker, batteries). Can use this to solar-charge the house bank down the road, too.
Charging:
  • Alternator → intermediary to not fry alternator or lithium (TBD, if possible: external regulator?) → 12V lithium house bank. The BF90 dedicates approximately 30A to charging with the remainder powering the motor itself (44 total, IIRC)
  • 12V house bank → small DC-DC charger → lead acid starter. Occasional top-up as needed, or trickle at home
  • 12V house bank → eg Sol Buck Boost MPPT (recommended by EP Carry)→ 24V dinghy battery on return. Either the 10A cigarette plug version for simplicity, or the 20A hardwired version for faster charging.
Weight wise, I'm going from a 55lb Suzuki 6hp (excluding gas) to a 14lb EP Carry, so with cord call it 15, so net savings of 30lbs before battery. A 100Ah 12V lithium is around 25lbs quick math, so I'd only be saving 5 pounds overall with that, plus the loss of the house battery presently there, probably 35+ pounds, so call it a 40 pounds net savings off the stern. I'd then add a 6-15lb dinghy battery (TBD), call it 10lbs, so 30lbs net savings off the stern. Not a whole lot with these estimates, but it might be more in real life. But, I gain a lot more amp hours on the house battery and the ability to run the EP Carry all the time and have it charge by the Honda. My battery switch is broken anyway (can't turn it without pliers; seller gave me a set) so I need to mess around back there anyways, and update the electronics. So this is all a big improvement, but not a conversion or build-out. I just would like a second set of eyes to say "yep that would work fine" or "don't mix chemistries even with a DC/DC / forget a shunt / balancer / BMS" etc or you'll catch on fire etc.. I'm learning, but keenly aware I don't know what I don't know.
Thanks, All.
Lost the edit window...
In case it comes up, the idea behind this was minimizing mixing of battery chemistry (and states of charge between lithium), and to not have the EP Carry, drawing off the house battery, then over-draw itself from the starter lead battery, which can't be kept up with via the Honda's alternator.
I also wanted to avoid shunts and bus bars and other "yeah that'd be cool" things which for my long weekends and plug-in / check everything over at home, seemed not necessary. I also didn't want to just add a new large onboard CDory lithium 24V battery for the EP Carry, and then also a charger from the lead acid, which would have been smaller and drawn down etc.. Figured I could use the Honda to add back the half hour of use twice each trip to that, and the starter is basically fine for a long time without even being topped off.
I upgraded a bunch of my electrical system last year and switch my house bank to LiFePo4. Don’t go thinking I know what I’m talking about but here’s a couple things for you to research. ( I did notice you were not able to keep the EP Carry in your cart for very long so I wanted to respond quickly)
Why not keep the alternator to the start battery? It would be a much simpler install and probably a better charge profile for your house bank.
You already would need a dc-dc charger, that would be most likely easier on your alternator also.
in my case I did notice that the charge start within second of starting the engines so you would not be loosing much charge time on your house bank. That would be also one less thing that could go wrong and affect you start battery and the restart of your engine.
I’m sure others will pitch in with real knowledge.
I agree with Stephan, connect the alternator to the start battery as well as the dc-dc charger for the house battery. I see no downside to this and keeping a trickle charger on the start battery at home won't be so critical. I know that I would forget to connect the trickle charger now and then after getting home.
I just purchased an EP carry for my 22' cruiser to help me with docking. I will also be running it from my 12V LiPO4 house battery. First test will be tomorrow. You did not mention, BUT IT IS ABSOLUTELY NECESSARY to also purchase a 12-24V DC-DC converter if you are doing that. Joe Grez, the owner and designer of EP carry (and a friend of mine), sells one for $100 but you may be able to find one that is less expensive on-line. However, the output on the 24V side needs to be at least 20A, and most of the ones I have seen on Amazon don't go that high, and even if they do, the wires coming in and out are not adequately sized. You will also need to use heavy duty wires (at least 10guage) and a 40A fuse. Finally, you will need a switch or disconnect between the battery and the Dc-DC converter so it's on only when using the motor. I suspect, but don't know for sure, that there is a small current drain through the converter even when not in use.
