Peter & Judy
We are just back from spending 10 weeks of the last four months on and around Vancouver Island. All in all a successful summer with a great deal of learning from our first summer of Salt Water Cruising. On fresh water we usually beach tie so that we can get on and off the boat at will. Only once did we swing on the anchor at night. With the effect of the tides this is not possible on the ocean and most often we anchored and then added a shore tie rope. One of the problems with the C-Dory is that the flat bottom and the high windage, especially with the camper top on, you get a lot of movement on anchor with even the slightest breeze. This was especially noticeable on a few occasions in small coves where winds were often confused. I spent one afternoon in the cockpit enjoying the sun and trying to read, but with the winds I was constantly moving. Meanwhile the deep hulled boats and the sailboats hardly moved. After an hour or two I was feeling quite seasick. We ended up moving to where we could shore tie. There was one or two other cases where we could not shore tie and when the wind came up we moved a lot.
My question is, If I were to hang a drift sock off the stern of the boat, would it reduce the amount of movement in the boat while at anchor? If you have tried this or have other solutions I would be interested in hearing from you.
