CaptainWanabe":159jk93n said:
https://www.fluxmarine.com/outboards
I just saw these new electric outboard motors from Flux Marine. If anyone has any experience with these motors or if anyone has insight to what it would take to run 2 of their 40hp motors on a Venture 26’. How many solar panels it would take. Etc.
For starters this is not a proven company, and I don't believe that there have been any retail sales. One of my concerns is that these are relative less expensive that other larger outboard motors. What is the long term longevity of these motors? It is unknown.
Two 40 hp electric outboards on a Venture 26? That would give you displacement cruising speed--it would don't plane the boat, so you would be limited to speeds in the 8 knot range in all practical use. The range of the boat would depend on the battery capacity.
Solar Panels? You want to run the outboards on solar panels, without the extensive Li'FePO4 battery bank it will require? It would take more than the surface available on the Venture 26. That would be just to charge a battery bank--not run the boat directly.
Figure even with the cheaper Li batteries you would be looking in the $50,000 range for at least 48 volt battery packs. Many of the electric motors with higher HP are running higher voltage systems.
Not going to happen.
