Active member
- Joined
- Nov 2, 2003
- Messages
- 21,619
- Reaction score
- 10
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Vessel Name
- thataway
I cranked out three projects in a few minutes--my appologies, but I don't take my high end Canon camera into the shop--so some the photos are not in good focus--but the idea should be there. Photos on page 7 and 8 of Thataway album:
I wanted to make a support for a fuel pump to transfer the 80 gallons of fuel I had removed from the C Dory 25 when we put in the new cockpit floor. I drilled the wood, and fixed the screws, before I mixed the fast set West systems epoxy. This is 5 min. epoxy I used, with filler if necessary for bonding items to the hull etc. You can hold blocks in place while this epoxy sets up--then glass over if necessary later. Great stuff, and much cheaper than the small tubes--see first picture.
The L bracket is coated with epoxy and assembled with two screws. I show pictures of the 105 epoxy and 206 hardner with pumps. Next photos of the various fillers I use most of the time--I have another half a dozen in my project box. The epoxy is metered, then cabosil added until it is stiff and will "stand" by itself. Then I add a pinch more of the microlite filler. This is mixed to a peanut butter consistancy and then spread in place. Since I am metering I had surplus, and then ran the tool--again a West Systems item which is reusiable. I clean my "tools" with fast orange citrus hand cleaner (one gallon size lasts several years for the hands and tools). After cleaning off the surplus, the fillet is ready to go, and allowed to set up.
Next I took a deck section I still had arouond this is from a 70's era Pearson 30. The cleat is fastened properly in plywood, not thru the balsa core--plywood is placed in the mold along with the 3/4" balsa core. Note that this 30+ year old boat has fullly intact balsa cored deck. The holes in the plywood were epoxy coated and well sealed.
I drilled a half inch hole right at the end and then extened it so you can see the under cutting with a Dremel drum sander. This makes a very neat cut about 1/4" deep, removing the balsa core. The balsa is replaced with the epoxy mix--this entire process took a couple of minutes--and should be included in the production line process for all thru hulls.
As you can see the sides of the hole are wiped clean with a popcicle stick and no more drilling or sanding is required for putting in a fitting of 1/2" size.
Finally I drilled a 3/8" hole in the deck--not thru the inner glass. I used a Dremel cutter bit to route out the inside under the glass. Then epoxy filler is placed into this hole and pushed back under the edges. When a screw is placed into this epoxy "plug" there is great strength and no possibilty of water intrusion--again the way that any item which sits in water or can sit in water in a cored hull shoudl be put together--how long does this take? Two minutes at the most. Very simple and very effective in preserving cored boats. If there is adequate glass on the top and bottom of a laminate core, and one uses these very simple techniques, cored hulls are very effective and will last a long time. Any short cuts can lead to premature failure.
