The new glass door is installed. Many pics in C-Cakes album, pp 4-5. Diamond Seaglaze was really helpful and easy to work with. They sold us a new glass panel, wrapped it in cardboard to protect it while we came back home. Total cost less than $225 including new gaskets and tax. Had we shipped it the cost would have about doubled. The door comes off the same way a house door does, pins in hinges. There is a deep gasket all the way around the inner side of the door frame that covers the raw edges. That is easily peeled away. The glass is held in place with a urethane sealant adhesive, the same stuff that hold auto glass in place; it can be seen on the exterior side of the door. Our glass was easy to remove :amgry , just pick up the thousands of tiny pieces. To remove an intact glass one would remove the door lock first. That is easy except for the dead bolt. Diamond Seaglaze had to tell me how to do that. There are two set screws deep inside the lock plate, (see pics), that must be loosened and the dead bolt can then be removed. Once the lock is off (many pieces), the urethane could be cut from the exterior side and the glass pried out. The urethane remains springy even after curing so a very sharp blade and thin spatula would be needed. If anyone needs to do this contact me and I will be glad to talk more. And...if anyone needs a new piece of glass and you don't live here, near the factory outside of Vancouver, BC, I may be able to help by picking up the glass and getting it across the border for you. part of the high cost of having it shipped is paying a broker to get it through customs. There is the cost of the glass, BC tax, and sometime a small duty to be paid. We can then work out shipping. While I am not certain why the door exploded, I think it was due to screws used to attach the latch that holds the door open. They were long enough to contact the glass edge and tempered glass will shatter if struck on the edge.
