CAVU":vysdccme said:
Ross,
I use a large Rubbermaid cooler (120qt I think)...... If you plan to fish and cruise I haven't found a good way to keep a cruising cooler and a fishbox(of any size)-it's just too crowded.
Ken- I know you said you liked the cooler in the center of the cockit, but here's an idea that might work for you or some others:
Having the cooler at the aft end of the cockpit is inconvenient to some folks, but if you can raise it up off the floor so that the front of your shoes can go underneath it, this removes some of the akwardness of having it there, as some other C-Brats have found out before.
To accomodate two coolers, one could build a framework that would hold the lower cooler off the floor far enough to accomodate your shoes, as above, and then hold the second cooler over the top of the first with enough clearance between the two to open the lid of the lower one 8-10 inches or more.
This would allow you to stack two matched coolers up, the one with the greatest weight on the bottom, and the other one on top.
The frame would have to be mounted to the floor as well as the engine well's forward panel, and the top of the upper cooler could be made into a bait cutting board or whatever one needed since it was at waist height.
These two coolers would also be forward enough so that they would not be in the way when tilting the motor(s) forward.
Don't know if this would work for you, but it might for some.
Joe.
