Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,963
- Reaction score
- 298
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
FLIR has come out with a camera which attaches to the i phone case, and makes the iPhone into a infra red camera. The cost is "less than $350", and details can be found at:http://www.flir.com/flirone/explore/tech-specs.html
The image is more like a home inspectors (Or what a marine surveyor should be using), than the detailed camera which we see with the hand held FLIR units (cost $2,000 up) and the cameras on the boat, which start in the $3500 range. These cameras will not work thru window glass in the C Dory, but they may bring thermal images at a much more affordable price to all of us. The product will be available in early 2014.
First Image is from MacRumors.
Second image is from Tech Crunch.
Yes, there is going to be an android case, but I suspect with different size cases there will be some limits there. Also a developers kit will be available.
