The 22 I just bought is a 1988. It too had a leak, so I took the cover off to have the "cracked" plexi replaced. When I got it back it still leaked, so I took the flange off, and low-and-behold the seal where it was bedded was leaking, and allowed the balsa to get wet and "rot". Had to dig it out and replace the removed balsa with duraglass. Therefore, the balsa sandwich area is now totally sealed and impervious to water...but, guess what, the newly replexied cover was leaking between the rubber gasket, the plexi, and the frame. I will be removing the plexi and replacing the silicone that was used with rain-gutter sealant that is an improved silicone-type sealant. It hardens slightly more, and does so much faster. I'll make sure it has plenty so I don't see water on the inside between the plexi and the gasket. Anyway, don't let it be -- fix it, or you'll have more to deal with than a wet bunk. Ron
