From: MichaelOnTheClaraMae (Original Message) Sent: 1/17/2003 4:06 AM
>>You have a fuel flow meter? curious what you burn at say 18 mph cruise with the Honda my Yamaha 115 (2-stroke)sucks about 8 gph at that speed with three people and full load of fuel and water. I tend to average between 2 and 2.5 mpg. overall.
steve
Steve,
I don't have a fuel flow meter and so far don't even have a guess on Gal/Hr or MPG running my Honda BF130 on the CD-25. Most of the 20+ hours on my engine have been in high winds and rough water. I really haven't tried to take a measurement thus far. I have seen 2 to 2.5 MPG mentioned by some other CD-25's running twins, so I don't think you are too far out of line.
I plan to do make some long distance trips in the months to come and a fuel flow meter would be a welcome addition. Do you have one? What would you recommend?
Michael (Clara Mae)
I recently repowered my '86 22' Angler with a Mercury 115 HP four stroke EFI. Currently, I am running a 15" prop. I also installed a new custom aluminum 29 gallon tank and a Navman fuel flow meter. This model has come down in price since I purchased it. Sadly, I was only able to put a few hours on the motor (mostly after dark and at slow speed) since I installed the Navman because the lake has frozen. At idle, I am seeing .1 to .2 gph. At 3,000 rpm and 15 mph, I am seeing around 3.0 gph or 5 mpg. These units are really useful in confirming the best trim position at a given rpm/speed. For example, you can see how much efficiency you lose by bringing the bow down to stop the pounding in a light chop. It seems to be very accurate in reading "fuel used" and "fuel remaing." At least, it compares favorably with my dash mounted fuel gauge and is probably more accurate. When the lake thaws, I will get a chance to put up some more numbers. There is a Flow Meter thread on the CB's you can check out for additional info.
Larry
Larry thanks for posting the links to the fuel meter thread & Navman site I was going to say do a search but that's one of the great thing about this site everbody is willing to help out.
Michael Shearwater came with a Flowscan and I would not without one now. Two big advanatges over the standard fuel guage. They are very accurate so you know exactly what remains in the tank the other is trim adjustment, does not take much adjustment with the tabs or motor to see fuel use vary as much as 2 gph so you have the ability to really fine tune when cruising. Never thought about it until now but my buddies split gas with me on fishing trips so I just give em a total gallons used at the end of the day and everybody's happy.
steve
Forgot this the navman meter is the best value around, I love my flowscan and the analog display might be a little better to set trim with however I'm not sure that I would choose it over the navman if I were buying new because of the big price difference.
steve
Thanks for the information guys - sounds like the Navman is the way to go. This along with a Link 10 battery bank monitor are likely going to be "future" projects for me. I am going to have to lick my financial wounds for a while.
Michael (Clara Mae)
steve
Steve,
Michael (Clara Mae)
Larry
steve
steve
Michael (Clara Mae)
