I am pretty sure I need to change my fuel pick up tubes on my 19' 2008 Angler. the tanks are Moeller. I disconnected the fuel hose, took the barbed fitting off of the pick up tube aluminum fitting then loosened the nut that holds the pick up tube to the fitting onto the tank. No luck, then tightened nut again and put a wrench on the nut and one on the aluminum fitting, tried to loosen and still no luck. Is there a trick of getting the pick up assembly off of these plastic tanks?
