I installed new Moeller plastic fuel tanks in my 22 cruiser, but I think that the fuel pickups are not long enough to reach the bottom. I run out of fuel when I can still see fuel in the tanks. I think that since the bottom of the boat is tilted towards the center, and the tanks therefore sit in the boat the same way with the pickups at the outer port or starboard sides, fuel is not pulled from the tanks cause the pickup is on the high end of the tanks. Can the pickups be removed??? It looks like there is just a clamp around the molded plastic -- I'm sure there is an "o"-ring for seal, but can the pickups be removed??? Hate to cause any damage or danger from potential leaks. Thanks, Ron
