Fuel Vents???I read the other day about one of the Brats checking his fuel vents and found the vent hole pointed forward and no loop in the line. SO,, I thought I better at least check mine just in case, thinking no boat builder would install a tank vent that way more than once... Well mine must be the more than once boat because they were the same way his was. No loop in the hose and pointed straight down to the tank. I flushed the tanks right after I got the boat and I did get some crud out but not much. Maybe the previous owner never got in any rough water with it. Besides the tank is a 60 gallon aluminum, so maybe not in long enough to get saltwater in it. It was a pretty easy fix for mine. Just took the vent off at the tank, cut a short piece of 1/2 copper water pipe to couple the hoses, 2 feet of 5/8 fuel vent hose, and a couple stainless clamps. Looped the hose up to the underside of the deck and then down to the vent. It was probably 1/2 hose on the vent, but 5/8 fits perfect and was a lot easier to get on my barb. Not everyone has tanks like mine and yours may be a different size, but GUYS!! you better check yours just in case. The vents has 2 holes in them and I did turn them down and back before I tightened them up.. Mine is strictly a salt water boat and that don't mix very well with gas and outboards... :amgry
