Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,963
- Reaction score
- 298
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
Greg tells us the USCG uses:
Thus is is best to have our chart plotters set in this format. It makes it easier to both give the information to SAR, with less chance for error, and to then plot the location of an object by entering a waypoint, and determine if this is close to our position by doing a range and bearing of this waypoint on the chart plotter.
I just reviewed the steps necessary on Garmin chart plotters, which is what I use on my boats.
Go to "Home" then to "Configure", to "Units", "position Formats" and then choose:
"hd*M'" as our default. You can also check on this page to be sure that the map datum is WGS 84. (This page has System units (statute, nautical and metric) Position format
hddd.ddddd, hddd.mm.mmmm hddd*mm'ss.s" and MGRS military grid system) Time (time format 12/24 & time zone) Heading (auto mag variation, true, grid user mag var), Map Datum and pressure Ref. time (some GPS give barometric pressure readings)
My home location in hd.m' is N30* 25.527' W087.20561' in MGRS is 16R DU 67090 65080 I still personally find it far easier to find on a map with the degrees, minutes and seconds system, but the Government is always right!
The standard Latitude/Longitude format for
CISAR operations is Degrees, Decimal
Minutes (DD° MM.mm’).
