Halibut
Active member
Sep 30, 2006
4,698
23
2007
25 Cruiser
'Au Kai (Ocean Traveler)
I'm going to try Halibut fishing next month w/ some guys from work. I've got a nice, stiff 7' Ugly Stick and the proper sized conventional reel (Okuma) filled the proper line, a gaff etc. Just need to rig it.
Any tips, tricks, advice, secrets....? I've bottom fished before (in Hawai'i) so I have SOME experience, but obviously I'm "not in Kansas anymore". Thanks in advance.
Thanks rigby. It never occurred to me that this subject was covered before. :roll: :oops:
You will find few things of any import that have NOT been covered here before. :wink:
"WHEN" I catch one...I'm thinking more "IF".... :lol:
Whatever you do, don't set the hook on a hailbut and hand the rod off to somebody and don't allow any party fishing....thats where everybody catches and releases and you just keep the better fish regardless of who catches them.....this I know, don't ask me why....seriously, don't ask
Mark, Have faith my friend. And I saw on Deadliest Catch, if you bite the head off one of your baitfish it increases your chances. :twisted:
SleepyC :moon
There is a good book, How to Catch Trophy Halibut. Also www.halibut.net and google for salmon university for some good information.
I will be going out for several trips toward Cross Sound this summer. Can't wait.
SleepyC :moon
:lol: The only raw fish I eat is Poke' or sashimi. :thup
We discovered a great way to fish for buts, we just put our salmon rigs right on the bottom. flashers and hootchies. We tried this in Bamfield and Sekiu and caught more than we did in the same time jigging. And best of all no dogs. mbw
When you say "put on the bottom" do you mean troll on the bottom or do you mean you let them rest on the bottom? If the latter, pretty amazing!
Mark,
This upcoming month for halibut is my favorite fishing time of the year. It's taken me a couple of years of experimenting (and seminars) but I finally feel I'm doing enough right to have a decent chance to catch a fish.
Some important points:
- you have to be on bottom to catch these fish. You should have a good selection of weights to continually 'bounce the bottom' during various tides. If you're not bouncing the bottom, your not fishing. (12-30 oz range)
- In Puget sound your probably fishing between 100-200 ft. If you're off the coast (LaPush, Neah Bay, Westport), you may be in 300-500 ft of water. You'll need more weight in this case.
- In Puget sound the tides are great the second and forth weekends in May. The first, third and fifth are going to be harder to fish because of strong currents.
- I rig up with a zip cord (about 2' long )with fixed swivels on each end and a sliding one in the center. The leader with bait attached goes on the sliding swivel. You can buy the zip cord assembly and stainless halibut leaders with double hooks. Tie the weight to the bottom swivel with a 6" long piece of 20 LB test line. You'll get hung up ocassionally and will want the mono line to break instead of the 85 lb braid.
- For bait I use the white 9" B2 plastic squids with a large herring jammed into the skirt and secured to the top hook with a piece of thin solid wire(several wraps around the fish). This holds the herring securely and does not cover up the hooks. This setup is my own and has worked on several occasions- the squid add the visual component, the herring gives the scent.
- Halibut are dumb fish. Look for humps on your map and depth sounder and fish across them. Keep moving because the fish will be moving around as they feed- especially during tide changes.
- If your fishing off the coast, you don't bother with the herring. You can drop anything down and they'll probably hit it.
Good Luck! I'll be fishing in the Strait on the 8th and Memorial Day weekend. Plus three days fishing at LaPush (20-22).
"Caught" Halibut at Pea Soup Andersen's in Gustine CA (I 5 south of I 580) last night and at Syrah in Santa Rosa this evening. Both were grilled and tasty! Price at Andersen's was 1/2 of Syrah but wine country ambience versus off the freeway stop made up for most of the difference.
Just a thought "if" you don't catch any fish.
Bill Uffelman
Usually Las Vegas NV
Funny, Bill. :lol: I was just talking to my brother. He said fresh Halibut over in Port Orchard: $5.50/lb. :lol: But where's the fun in THAT? :wink: :crook
doryman, i meant troll as close to the bottom as you can. michael
