Alyssa Jean
- Joined
- Nov 2, 2003
- Messages
- 2,376
- Reaction score
- 0
- C Dory Year
- 2005
- C Dory Model
- user_field_choice.c_dory_model_16_Angler
- Vessel Name
- Alyssa Jean
While on our R/T from the San Juans to Ketchikan two years ago the Jabsco Marine head refused to pump water into the bowl to flush. Luckily we were in Prince Rupert and the marine store there had a replacement gasket/flapper valve. Take out 6 screws and the top/pump comes off and it is located right under it. Same thing happened last week, so I pulled the top again. Now I understand what is causing it. The lever that you throw back and forth to either pump water into the bowl or empty the bowl has a curved finger inside under the top. Looks like a big letter "J".The top of the "J" is the lever and it is hinged where it passes through the top plate. When the lever is in the right position (facing the head) it is in the position to empty the toilet. To the left it is in the position to pump water into the toilet. If you leave the lever in the empty position (to the right) the curved part of the "J' under the top is lifting a small rubber flap. The valve flap develops a memory if you leave the lever in that position. (I seldom use the head so it can sit like that for weeks or months)
When you do need to pump water for flushing the flap won't lay back tight and make a seal.
So. After pumping the bowl empty leave the lever in the left bowl filling position when through. The "J" is in the lower position and the flap can lay against the seal. I put a small label to that effect near the lever.
I will hear from Pat on Daydream on this I am sure. He has the only composting toilet on a 25 as far as I know.
