RobLL":3mw23itz said:
Sunbeam - I appreciate your posts, and look at the 11+ factors you list. I don't think I could sleep after anchoring, unless in a large group of experienced boaters also anchoring.
HiRobLL,
I can relate to how you feel. Even after thousands(?) of nights at anchor, I still always sleep with a "weather ear" just in case. That's not because I've gone to sleep with a setup I feel is marginal, but just because that's how I am and how the sea is. It's never quite like being in a parking spot with your car.
I had the benefit of spending my first year or so at anchor on someone else's vessel who was experienced. So while I still took it seriously, I was not the one ultimately responsible plus I had "lessons." The other nice thing is that it was a good boat, with good ground tackle. So I had an ideal introduction to it. (It just so happens the first four months were in your neck of the woods - Vancouver Island and north.)
[Note that as I mentioned before, there are many different opinons on anchoring; maybe as many as there are sailors
Anyway, this is just my experience and opinion (and there are many much more experienced sailors here on the forum)]
How many hours at a time would you sleep while anchoring in excellent to fair conditions?
As many hours as others will let me sleep
No, seriously, there isn't really a limit; I've spent weeks at anchor in the same place, so obviously sleeping every night the night through. Other times, it's been a new spot every night. And not always in ideal conditions or ideal anchorages - just the way it goes. One thing that really helped me was spending time in the tropics; this is because you can dive down and look at the anchor, both to check its set, and to watch how it behaves in less-than-perfect conditions. I felt more comfortable after that experience (even now in places where I can't actually look at the anchor).
If conditions are dicey, or there is some other reason for it (another boat came in and anchored too close after it was too late for us to move; weather came up; etc.) we would stand an anchor watch. This essentially means that one person is awake at all times through the night, monitoring things. Hopefully there is more than one person, so someone can sleep. But this is statistically rare. Much more often one finds a good spot, turns around three times (metaphorically), and then relaxes and sleeps well at anchor (with the weather ear slightly cocked).
A couple of things I do coming in:
1) The first time into the prospective anchorage, I'll just take a loop or two, scoping things out. Kind of a "touch and go." Including carefully making a loop around what would be my swinging circle to check the depths.
2) Anchor into the wind (generally speaking, with wind and current you may have to adjust). So get to your spot by heading up into the wind, stop all forward motion, and then let the anchor go, paying out the rode smoothly. At this point you want to be drifting backwards at a reasonable rate so the rode goes out in a line, not a pile all in one spot (you can use engine to reverse gently if wind doesn't do it).
3) If I have a chance, I'll make a waypoint at the anchor drop spot; this can then be used to set an alarm, if you want to. (Last year my first time anchoring in the 22, I also put out an anchor buoy, just because I wanted to get a feel for how the boat moved relative to the anchor - it is an "active" boat at anchor.)
4) Once you have the amount of rode out that you want, you can set the anchor. However at this point, if I have time, I like to let the anchor settle for awhile and just hang there and watch things. This also gives me time to get a feel for the anchorage. Maybe I'll end up deciding to move before "really" setting the anchor. I don't leave the boat right away at any rate, such as to go ashore (obviously this is different if, say, if you are in 5' of water on the beach at Powell).
5) Once I'm ready to set, I make the rode fast (not on the windlass gipsy), then slowly motor in reverse, gradually adding more pressure. Ultimately I give it quite a good amount of force (reverse throttle). Watch landmarks (shore usually, a couple of landmarks in a line) to see that you stop at a certain point (if you just keep slowly going backwards, you are dragging). Once you are good and set, when you let off the throttle you'll likely surge forward a bit, as the rode re-establishes caternary.
6) Now (or possibly before #5, depending on your setup), I rig a snubber. In my all chain days, this was 50+' of nylon three-strand. I liked a long snubber because I would start out with around 20' or so deployed, and then for those 3 a.m. times where I wanted to let out more rode, I could just let out snubber and rode together and re-cleat, vs. having to bring in rode, detach snubber, let out rode, re-engage snubber, etc. Very often, that extra 30' was just enough to allow letting more out and feeling good about it, and 3 a.m. is no time to have to fiddle with details if there is a good way not to. With a C-Dory you likely have rope rode already, so the snubber may be more just to get a fair lead around the windlass (I would still make it smaller diameter than the rode, so it is stretchier).
7) Now have a beverage and spend some time relaxing in the cockpit, and when you are sure all is good, you can go to shore, go to sleep, or whatever :thup
8 ) You can set a drag/movement alarm on a GPS, although if you are swinging around you will have to set it a bit "looser" or it will be going off constantly. I have also used a radar alarm in very dark places where there were no landmarks (no lights or etc.), but that takes a bit more power (maybe not a problem nowadays).
Last fall on Powell was my first time anchoring out on the C-Dory, and it is in some ways a whole different experience. As it turned out I was with my long-distance sailing buddy, so we were both used to the bigger/heavier boat, all-chain rode, etc. The C-Dory felt like a leaf! We had to get used to how it differed from the bigger/heavier boat. Funny thing is, quite a few people had said "Oh, it's a small boat and you will always be in shallow protected waters, so you don't need a serious anchoring setup." Well, that may be true much of the time (and of course the gear is a bit different), but I was glad I had a "real" anchoring setup, because even on Powell there were a few nights where we had real wind and waves (even after having plenty of time to find a "good" spot). One night we did keep an anchor watch, as when the storm clocked past a certain point we had waves coming in, and the up/down motion of the bow, plus the swinging, can affect the anchor set (there was no 360º protected place where we could anchor and not be sandblasted). All was well but we had to laugh as here we were, sitting anchor watch, in this supposedly "always in sheltered water" little boat. (Granted, you will be in sheltered water much of the time and some places really are always sheltered and easy.)
I would say to find a nice "easy" spot on a good day and practice anchoring over and over, and that will give you a feel for it, and for any improvements you may want to make in the setup (fair leads, etc.). Like doing touch-and-gos in a plane.
Sleeping/spending time at anchor is my favorite - the boat really feels alive as compared to being at a dock. Plus it's like having your own island and moat! :thup
