GCULHANE-
Here are some selected comments I've made earlier describing the C-Dory "Classic" as opposed to the later Cruiser and Angler models first made in 1987 and thereafter:
All 22's before 1987 are the classic models. They look like an 1987 or later Angler externally because they have a shorter cabin, but have a diffeerent layout in the cockpit and the cabin.
The pre-87's have a short cabin, an open port side of the interior bulkhead to the v-berth, a shortened dinette table and single seat to port, a small space to the rear of the helm to starboard, a lower roof line (no center bulge), the stern has a center motor well with both sides at the stern open and a shelves below, the rear cabin bulkhead and door are wood, and the boat has a flat bottom that looks exactly like the bottom of a clothes iron.
Most of us have the 1987 or later models. Those of us with the Cruisers love them for their interior amenities: galley, sink, dinette, convertible berth, private v-berth, etc. This is a conventional design that sells exactly because it has appeal to the couple/family buyer and requires little modification for most uses. The Angler, the more direct descendant of the Classic CD, is more like the original boat with a larger cockpit and a more spartan interior. The factory for a short while offered a Sport Fisher (I think that's the term) which is more of a day-use fishing boat without the rear cabin bulkhead and more dedicated seating.
The original Classic design probably seemed a little unorthodox and less immediately appealing to potential customers. The open rear sides of the cockpit and narrow central engine well don't look like a typical purpose designed fishing boat at the boatshow. The interior lacked finished definition of space and was missing the elements of spousal appeal and privacy that create the consensus necessary to write the down payment check. And the absolutely flat, seemingly cut off bottom was to most an enigma that just left most shoppers wondering. Thus the re-design of the boat for 1987.
But, having looked at and considered this design for a good number of years, it makes more and more sense, especially for use as a dedicated fishing machine.
The large and very open cockpit has loads of room and can be modified to accommodate a lot of fishing, crabbing, and other equipment. Rods, nets, livewells, fishboxes, traps, davits, dingies- maybe you can't have them all, but you can have more of them than with a two foot shorter cockpit with closed transom corners.
Internally, the cabin can be modified as needed for your specific needs. Lots of room there to tailor the boat to your fishing/boating plans. A
project person's dream with a few tools and some time.
The hull's secrets are usually untold. The absolutely flat bottom rocks somewhat less at rest than a shallow v. ( and a lot less than a deep v, which the CD's are not). It planes relatively easily, like the shallow V of the later boats, and sets flat on a mud or sand bottom with the tide out, so you won't want roll out of bed when the tide takes its leave, or need a gimballed stove for breakfast. Plus, it's draft should be even shallower than the shallow V.
Overall, it appears the Classic C-Dory was very carefully and cleverly designed as a utility fishing boat with a lot of adaptability, but not very well understood by the public after the typical quick glance or look at the boatshow or dealer's lot. Probably even a good explanation of the boats qualities and design solutions by a salesman would be met with unsettled indecision unless the prospective buyer had a wealth of knowledge and experiences with fishing boats of this size and purpose.
But that's not to say that we can't today appreciate these Classic C-Dorys for what they are and how they can be used. As a dedicated fishing boat for a person who knows what they're going to do with the vessel and can determine how it fits their needs, it may be a very good fit. Especially if one likes projects and has the time to do the work. As such a boat like this actually provides a second hobby of boat modification that is entertaining in its own right.
The standard Angler has always come with a solid Alaskan bulkhead to the rear, to my knowledge, but custom boats can be ordered.
They did make a Sport Fisher model of the Cruiser with a cut away rear bulkhead a few years ago, but have discontinued it. It had bench seats inside instead of the dinette and galley, probably best suited for charter fishing use.
It would be easy to get an Angler modified with an open rear bulkhead, as a cut-away job is a lot easier than an add-on!
As an example of a custom boat, at the Factory Party two years ago, we saw a custom order 22 Cruiser with the galley eliminated and a stand-up enclosed head substituted in the starboard rear of the cabin.
Such custom orders are probably not sought out by the factory as they tend to take additional time to produce, but may be available for a fee.
If you like the Angler with the bulkhead, it's readily available already!
Hope this helps!
Joe. :thup :teeth
