- Joined
- Nov 2, 2003
- Messages
- 8,561
- Reaction score
- 1
- C Dory Year
- 2005
- C Dory Model
- 25 Cruiser
- Vessel Name
- Daydream
The discussions in another thread about Mac's range in the Ranger 25, and how much range is needed in Alaska got me thinking about this topic. Pardon if this kind of bounces around a bit! I will echo the statement that there is NO problem finding fuel every 100 NM or so between Washington State and Ketchikan, AK - the key spot we were unsure of when we were planning was Hartly Bay, because it is a long way from Shearwater to Prince Rupert - this is a great modern facility now. We fueled on the trailer at a gas station in Blaine, WA; Gorge Harbor, BC; Sullivan Bay, BC; Shearwater, BC; Hartley Bay, BC; Prince Rupert, BC; and Ketchikan, basically running off the top half of the tank. But some day we might need to go farther between fuel stops, and it seems prudent to have a firm grasp on what you can do and how to do it.
With the re-propped Honda BF150 (15.5 x 15 x 3 AL) we are getting much better economy than before on our CD25...We now routinely turn in 2.5 NM per gallon (calculated, NM traveled per GPS trip computer divided by gallons used), of course that is a blend of fast transit and slow cruising for sightseeing. So for planning, I think I can very conservatively count on 2.0 NM gallon. With a 100 gallon tank, and a 25% reserve, I think I can count on a 150 NM range for whatever conditions I may encounter.
Maximum economy though I presume is attained at hull speed. I know the formula for hull speed is 1.34 times the square root of the water line length of the hull. I don't really know the water line length of the CD25 however. I think Bob Austin estimated it at 22 feet? If so, that would give a hull speed of about 6.2 knots. I am wondering if the water line length could be as short as 20 feet? That would give a hull speed of about 5.9 knots. The reason I wonder this is that I had a great chance to run Daydream on the kicker in Upper Priest Lake on an absolutely mirror-like surface, no apparent wind and of course no current. The kicker, a Honda BF15, gave us 5.7 knots (SOG per GPRS) at well below WOT (maybe 3/4 throttle, we do not have a tach on the kicker) and at WOT (and significantly more RPMs) it only crept up to 6.0 knots. I have also noticed that the BF150 gives its most economical performance per the Navman somewhere right around 5.7 knots - when I get up over 6.5 knots it really drops off. This makes me think hull speed is probably actually 5.7 knots, but that does not conform to the formula. No doubt there are other factors, but that seems to be what we are finding.
For figuring out range in a tight spot - a long ways to go between fuel stops - obviously 5.7 knots seems to be the best speed for our CD25. The fuel used by the BF150 at 5.7 knots does register on the Navman - it jumps all over the place by instantaneous economy. Actual computed economy is always less than instantaneous readings, but we see instantaneous readings around 8 - 10 MPG. Assuming it is actually somewhere around 5 NM per gallon at 5.7 knots (and I think it is higher, but have never run exclusively at this speed, so no way to really check), my range at 5.7 knots would still be at least 375 NM using the 25% reserve rule.
But the fuel flow to the BF15 at 5.7 knots does not even register (or register accurately) on the Navman - at 5.7 knots it jumps between 18 - 38 MPG, which I am pretty sure is an artifact of the inability to register really low flows. Now, this seems to indicate that the flow to the BF15 to attain the same 5.7 knot speed is less than the flow to the BF150. If the same amount of fuel was flowing to each engine at 5.7 knots, the Navman would register the same but it doesn't. This seems to fly in the face of what Bob was saying about the fuel required being based on the amount of "work" the engine is doing. Comments, Bob?
Anyway, it seems clear to me that in a tight spot, I would get the absolute maximum range running my BF15 kicker at 5.7 knots - does anybody have any idea of what kind of economy I might really be getting or range I would have doing this? I suppose I could put exactly a gallon (or maybe two) in the little day tank that came with the BF15 and see how far it takes me...
