Well-known member
- Joined
- Oct 30, 2006
- Messages
- 12,650
- Reaction score
- 32
- C Dory Year
- 2005
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- Brat # 2202
- Vessel Name
- Sleepy-C
Casey said:
For that very reason, I asked if the Hypervent is marring, scratching, or otherwise adversely affecting the gel coat under the mattress area in the Vee Birth.
Has anyone that is (or has ) used the Hypervent noticed anything like that?
SleepyC :moon
"It seems to work quite well and my only complaint(s) are that (1) it's expensive, and (2) the bottom side of the Hypervent will tear-up your skin. Underneath it's like thousands of half inch nylon spikes ... and they're Sharp! I would recommend cutting it slightly narrower than the outside edge of the V-berth area (particularly around the porta-potty). It you cut it "flush," that raw edge will be uncomfortable on bare skin. (Don't ask me how I learned that.). You have probably seen green doormats made from stuff that looks like stiff fake grass. Hypervent is very similar.
SleepyC :moon
