Wood Zeppelin
Member
- Joined
- Feb 9, 2016
- Messages
- 362
- Reaction score
- 0
- C Dory Year
- 1997
- C Dory Model
- 22 Angler
- Vessel Name
- C-Creature
This will be a hard question to answer. Safety is key, and I understand not many are qualified to make engineering level safety recommendations. But I'm looking for perspectives/thoughts..
I have a rare Jeep Scrambler from the early eighties. I think of it as the C-dory of SUV's. It goes anywhere, and looks cool doing it! I restored it from the frame up, and modified it. So it's not really the original vehicle anymore. It's original towing capacity is apparently 2000#. I tow a 16' C. But I want a 19' A, (probably not a 22' Angler, but will through it in for perspective).
Towing Weights:
16' C - 2025#
19' A - 3258#
22' A - 3675#
The 19' is significantly heavier that the 16'.
(1) It would seem the most important thing is braking. I have upgraded the braking system on my Jeep to match the increased tire size. I would also get trailer brakes, which I would think would handle the braking concern (?) Any thoughts on that?
(2) Next, drivetrain: The engine has been rebuilt and had more torque. The manual transmission has been upgraded to a much stronger unit than oem. The transfer case is oem, but known to be one of the toughest. The rear axle is strong, but could be improved if needed. I plan to lower the axle gear ratios for better towing. I have heard I can monitor the temperature of the transmission to make sure it's doing ok under load. Yes, I plan to drive over mountains sometimes, but not regularly.
(3) Tongue weight. This doesn't seem to be listed on the C-dory website. I assume this can be adjusted by moving the position of boat as it sits on the trailer(?) This is a concern, I'd like to know the specs... anyone?
(4) Overall stability. The Jeep is light, with a GVW of 4000#. I believe the overall vehicle weight should be more than the trailer, but not sure how much(?) anyone? The wheelbase is 103" long, with a track width of our approx 55" (center of tires). I am concerned about overall stability. I think the trailer brakes take away much of this concern (?) Thoughts? But I'm still concerned about the weight ratio between tow vehicle and trailer. Should I be?
(5) My main thought is that I want to be safe. If the Vehicle is rated to tow 2000# and I'm already towing 2000#, I figure I'm at my limit. But I really want a 19' someday and if it's possible to safely increase my Jeep's towing capacity, I'd like to do that. After reading this, who thinks it's doable? Who thinks not?
thank you!
Any other tips on increasing tow capacity
Towing Weights:
16' C - 2025#
19' A - 3258#
22' A - 3675#
thank you!
