Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,822
- Reaction score
- 160
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
spuncopper":6zb9zn4o said:Hey Littlebear,
Here's somethings to consider since it is obvious you'll be towing. These weights are for the hulls only, doesn't include engines, trailer, gas, water, gear, etc.:
CD 22 Cruiser: 1925 pounds
CD 25 Cruiser: 3602 pounds
Venture 23: 3020 pounds
Tomcat 255 Cat.: 6000 pounds
Do you already have a tow vehicle? The bigger the boat the bigger the tow vehicle the higher the cost.
That is a little misleading. The C Dory 22 is going to be in the 4500 lb range ready to go. Bigger Sun's, 1/2 ton Pickups will do. The 23 is about the same weight--maybe 500 plus lbs more.
The C Dory 25 is light at 6500 lbs. I towed on recently and it was a strain for my Yukon XL with tow package. Figure on at least 7,000 lbs, and some of the bigger and higher rated 1/2 tons or a 3/4 ton.
The Tom Cat is going to be at or over 10,000 lbs on the trailer and I would be thinking of at least a 3/4 ton Diesel, or a 1 ton.
