Aurelia":9msi0ade said:
Maybe its the angle Les but that canvas doesn't look very good. They are all some form of ugly I guess but you should look at lots of Cbrat albums and experiment with different angles and volumes. The canvas just doesn't look as proud at the rest of the boat. Keep refining....
We looked an many and came up with our own variation and I think you can do the same with the Marinaut. At least in my opinion, ours came out big and tight and purposeful looking while many of the King products and others I have seen on the same boat look a little ill.
Just leave a bimini on at the show, they all look better that way. Or do a permanent T-top bars off the roof type bimini. Some of those make me jealous.
Hi Greg,
Aesthetics are always a tough thing. The funny part is that I designed the radar arch, transom safety rail, and the custom camper canvas that's on an awfully lot of C-Dory 22's (the radar arch and transom rail became "factory" options).
The thing with the camper canvas on the Marinaut is, quite frankly, "how high do you want to go?" You can see that's there's not much rise to the camper top from the aft end of the cabin top, yet there's still 6' 4" of headroom under the stainless bows. It might have looked better with more rise but all that would do is increase the windage, the size of the bows to be stored and added height where non is needed (for most folks).
The width is set by the boat. The length is set because the rear curtain needs to be in front of the motor and because of the "dam" across the back of the Marinaut (the one that runs across in front of the aft decks and motorwell) it makes a natural stopping point and a perfect place for the aft curtains to fix to at their lower ends.
Movement inside the cockpit isn't restricted so one can walk right to the front of the motorwell (or put a chair there) so in order not to lose space (volume) inside the camper canvas the aft curtain is very nearly vertical. Any more slope to it would have meant folks couldn't stand up all the way to the motorwell.
The panel sizes are a natural result of the geometry of the boat. The aft line of the cabin is sloping, not vertical. That means where it meets the side deck is further aft then where it meets the cabin top. If you're going to have a useful entry area (just aft of the cabin) the opening need to be wide enough to be comfortable to use and the sloping cabin back pushes that aft. The entry opening width sets where the pivot point is for the main bow, which in turn sets the length of the entry panel and the aft side panel.
All that remains are the aft panels and the natural breaks there are one for each aft deck and one in the middle for the motorwell.
Unless we do something only for the sake of aesthetics there's not much to change. It's got all the height, width, and length the boat can accommodate.
The nice thing about our boats is that folks get to pick exactly what they want with regard to colors and design (where it can be accommodated). So the new owners of this Marinaut were able to pick a hull color, striping, interior fabric, and camper canvas fabric that they like and will work in their area.
Here is the PNW we're used to seeing darker colors. I'd dare say if the same camper canvas was done in Mediterranean Blue or other dark color it would look more like what you describe.
