Writer_Ron
IMO the "trick" is to use one of the increasingly popular "oscillating multi-tools" (I own a Bosch model). In less than 10 minutes I produced about six-feet worth of straight cuts that were actually neater and cleaner than the original C-D factory-made cuts I found under the rubber molding. I simply marked the larger opening with painter's masking tape and kept making neat plunge cuts with the multi-tool.
Note that my iPhone camera adds distortion to the edges. They are straight. Really!
The toughest part of the job was to remove the residue from the existing rubber molding (which is metal reinforced).
I decided to "square out" the opening so I can trim it with teak molding. That's my next job.
[/img]
