SeaSpray
Active member
- Joined
- Mar 11, 2004
- Messages
- 1,016
- Reaction score
- 3
- C Dory Year
- 2004
- C Dory Model
- 22 Cruiser
- Vessel Name
- SeaSpray
I may have lost something from my Johnson 90.
If you look at the last picture in my album you will see a screw hole in a recess on the port side of my gearcase. This is not visible if the motor is tilted all the way down (hidden by mounting bracket). I usually tilt it all the way down when stored to let the water drain from the motor.
This weekend I just noticed it looks like something is missing from here. At first I thought it was a grease cert but after looking in the manual it looks like the bonding wire was meant to go there. In the picture you can see the bonding wire connected just below this place.
Anyone know if I have lost something from here? Did they just put the bonding wire in a different spot?
I think I noticed this because I did loose the plastic intake screens from the water inlet. I have no idea where they went or how they could have been lost but they are gone.
Thanks for any ideas,
Steve
Steve
