This is a continuation of Junkyard Trailer
Stainless Steel Connectors
As previously mentioned, this custom Baja trailer has all stainless steel connectors. I’m sure some of you are very familiar with stainless steel, but I wasn’t except that I knew it existed and it was expensive. For those of you who only know what I knew then, I’ll bring you up to speed. I’m not an expert, but I’ll try to explain what happens.
When you put a stainless nut on a stainless bolt, it goes on great until it gets tight. When you put the pressure to it with a wrench to tighten it, you will gall the threads. Okay, I looked up “gall” in the Webster’s to see how this fits what actually happens. As close as I could get was “an irritation or annoyance, or a cause for this.” I can relate to that!
Plain and simple, the interaction between the nut and bolt under significant pressure results in the destruction of threads and seizure at that point. The nut is there to stay! This can be avoided by using an anti-seize lubricant. I have some made by Permatex and I suggest using it sparingly and don’t get it on your hands as they will be silver for some time to come.
Looking close at my spring hangers on the trailer, I saw a nut that was about an 1/8 th of an inch from being tight. I put a wrench on it to tighten it and it wouldn’t move. This resulted from using an air gun and the nut got hot and seized before getting anywhere near tight.
ALL the nuts on u-bolts holding the spring assemblies had seized and had to be cut off and redone! Many more stainless connections were the same way. Encountering this problem on the road would be a disaster. Some had to be broke off while others had to be cut off with a hack saw. Enough said on this subject!
Bill
Wheeler Dealer - sorry but I could not access the other thread any longer and I have one or two more items to post before I'm done.
Bill
