Salmon Slayer
- Joined
- Jul 4, 2005
- Messages
- 132
- Reaction score
- 0
- C Dory Year
- 1981
- C Dory Model
- 22 Angler
- Vessel Name
- Holly May
Congratulations Tom&Shan:
A couple of things per your questions, as far as electronics; ensure you have a fixed mount VHF with a good antenna, a hand held will not likely have the range for where you will be boating. Do purchase a hand held though as a backup if you can afford it and install a good depth sounder or fish finder if you dont already have one. Another tip I learned on this board (unfortunately after the fact) is to attach a piece of STARBOARD or similar material to the transom with 3M 5200 and then screw your transducer mount into that instead of screwing direcly into the hull.
With you trailer, I dont know of too many folks that jack up their trailer and put it on blocks except for long term storage for the winter or when you will be gone for a long time (I am curently away from my boat for a year and a half and did that to mine). This relieves the strain on the leaf springs, keeps from flat spotting the tires etc., if its hot in your area I would also cover the tires to help keep them from being damaged from the sun and cracking (I dont have that problem where I am at).
As for backing, and in addition to the excellent advice you have already received, I have a very tight area in which to back into my drive and I have found that if I pull up farther past the drive and then begin to back toward the drive I have more time/space to make any corrections and get lined up properly. I can make a gentler turn and then cut it sharper once I get lined up properly. In other words, I used to pull up only to the point of where the outboard was just past my driveway and then I tried to back in with too sharp of an angle; pulling a couple of boat lengths further up the street and then backing toward the drive with a shallower angle made all the difference for me.
Finally, I make a second vote for naming your boat "FIT"; that one made me laugh out loud.
Andy
Andy
