Active member
- Joined
- Feb 23, 2012
- Messages
- 3,990
- Reaction score
- 16
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
Hi folks,
My 22 has a ~110# Honda 8 mounted to starboard (swim step is to port). That, combined with two batteries in the starboard lazarette seems to make the boat list to starboard. Given that I'll be doing a fair amount of solo boating - and so I'll be to starboard too, I'm wondering if I should make any change to help compensate for it. I say "seems" because I haven't really run the boat yet, but when it was being lifted on land (center-point slings), we had to put quite a bit of weight on the port side to keep her from rolling to starboard. However, maybe the "air balance" was more dramatic than it would be in the water (?).
Now I'm in the position of making some changes without the benefit of real, on-the-water experience, so that's why I'm asking you all. I'm in the middle of some projects and need to make decisions that will affect lateral trim before I can re-launch and sea trial - namely replacing the batteries, cables, switches, and associated gear.
I want to keep the swim platform to port/kicker to starboard for a couple of reasons: one, because they are there; and, two, because I like the clear, cable-free approach to the swim platform on the port side. I realize that the trim tabs (another project in progress) will probably compensate when I'm underway, but I'd like to not list to starboard while at anchor, and it seems it would be nicer not to have to "push" one trim tab all the way down always just to trim the boat laterally.
So, options I'm considering:
1) Batteries
Keep batteries in starboard lazarette, move them to port lazarette, or move them to cockpit between fuel tanks.
I'd like to keep them in the starboard lazarette if possible because it's already a "bad" lazarette, what with it having all the motor cables running through it, and having only a partial floor/sides. The port lazarette is a more useful, tidier storage compartment and I would also like to keep it available for a possible future propane locker, so I really don't desire the batteries there, using it up. That said, the batteries/etc. will be around 150# so that would be an effective 300# move just by itself (and I could glass in the starboard laz if I really wanted to). I imagine that would solve the imbalance.I don't think I really want the batteries under the splashwell between the tanks, because I could put larger items there, such as fenders or a spare tank of fuel, but it is a possibility.
2) Kicker
I could change from my "fully featured" kicker (Honda 8D with electric start) to something much smaller/lighter and lose 70# or so. But I have the Honda and it's like new, so my preference would be to at least try it.
3) Trim with cargo (or ballast)?
This is the question it's harder for me to put a number on and/or to really visualize in use. Easiest (best for now) would be to keep the kicker I have, put the new batteries into the starboard lazarette where the current ones are, and plan to trim with things I load onto the boat. But I'm simply not sure if this will be feasible. I plan to use the water tank (I like to anchor out), so I can't count on keeping that full to add weight to the port side -- it's as likely to be nearly empty as it is to be full. And of course the under-galley cabinet is just begging to be filled with stores (why is it that everything seems to add weight to the starboard side?! :cry ).
So, can I load enough into the locker above the water tank, the locker under the dinette foot area, and the forward under-seat area locker to compensate? That's the big question. For those of you have got this far and are still awake, do any of you run/moor like this? Especially solo and perhaps with a not-full water tank? Are you able to keep enough/heavy stores on port side to compensate for a kicker/batteries/person on starboard? Do you add actual trim ballast? I'd hate to move the batteries over only to find out it wasn't really necessary (especially since I'd prefer them on starboard); OTOH, I'm about to put in all-new batteries, cables, and etc. so now would be the time.
Thanks for any input. I've searched and found some discussion on this, but not an exact match.
Sunbeam :hot
1) Batteries
2) Kicker
Sunbeam :hot
