krc
Member
- Joined
- Nov 6, 2017
- Messages
- 121
- Reaction score
- 0
- C Dory Year
- 2006
- C Dory Model
- 25 Cruiser
Had an issue this weekend. Anchor dragged into a cable at about 35' (SF delta).
Noticed an issue pulling up as it got very slow. Eventually popped the breaker. Found the breaker (new to boat). But, got out the hand crank and tried to get it up. We able, finally, using the boat hook and two people precariously perched on the bow, free from the cable. And, windlass seemed fine.
But, one thing we couldn't figure out was how to release the tension? Or first thoughts was to drop the anchor away quickly, but how is this done? It seems like if there is tension the clutch won't free up at all (even with the cog away). Is there some "trick"? I had just the day before pulled the entire spool out (15' chain, 150' 3-strand), and I had no issues then but the load was substantially different (enough to blow a fuse vs pulling out by hand with no initial load).
Frankly, if you have to release anchor quickly and circuit is blow, what do you do?
