Hooks
- Joined
- Sep 20, 2015
- Messages
- 20
- Reaction score
- 0
- C Dory Year
- 1998
- C Dory Model
- user_field_choice.c_dory_model_16_Angler
- Vessel Name
- Missy (for now)
Hello Brats, I'm new to the board and to the boat....
I've searched fairly extensively for some time now, and thought I'd put my project out there. As I reach and install the final solution I'll organize and keep a file for future folks who have a need for a live bait well. My boat is an angler 16'
My plan is to install a new thru-hull fitting in the transom, location sump, adjacent to the bilge pump. Mount the pump sideways, and flex-pipe to the cockpit bow storage and mount a 13 ga. ultra tank, starboard side.
I would discharge immediately downhill through the starboard.
I like this location because the boat is stern heavy to begin with, the water weight would help balance the boat, and it keeps my fishing floor space open.
So here are my direct questions.
1. Does anyone have an example of their system I could see photos of?
2. Is there a better idea out there? And yes I definitely need a bait well, and recirc to keep my mac alive.
3. What is the appropriate process, considering the balsa core, for the thru-hull? I've read over-drill, fill, re-drill, Dow seal. I'm slightly concerned about over-drilling as it seems more vulnerable than drilling, epoxy sealing, dow seal the thru-fitting. Thoughts?
4. Anybody aware of a way I could also use the pump for washdown, and bilge too?
5. The cockpit has a raised floor, which has a void area beneath it for cockpit drainage. In the bow storage, the previous owner installed plywood. My plan is to screw the well cleats off to the plywood. Or install new marine ply....same idea though.
6. Any other key stuff I should be aware of? Loops in the line, backlfow, air lock, valves, better ideas, etc.
I absolutely love my boat and have done a couple 40+ mile trips out of santa cruz for bluefin recently. Saturday we had 5 on and came home empty handed. I plan on changing that this weekend.
Thanks for any help and advice you can provide.
PS - I am also looking for a local stainless steel fabricator for rocket launchers and etc. if anyone has a contact. I currently have Mark Reeves of Railmakers NW building my bow pulpit, and looking at my rocket launcher fab too. Great service so far.
Bob
Bob
