Lowrance E-60R Fuel Flow w/Garmin 4210
Rwinemaker
The posts I've read suggest the Garmin fuel flow is not accurate at flows below 1.0GPH so I went with the Lowrance EP-60. My problem is I have a Garmin 4210. I thought NEMA 2000 devices worked on systems manufactured by different companies. Has anyone made Lowrance work with Garmin?
You'll need a NMEA 2000 backbone with terminators in the boat, and then each unit connects via T's in the backbone to send data across the network.
Lowranse has some good NMEA 2000 information on thier website, as does Maretron.
