Joel, the 3 piece set up is as Jody shows is much easier to get the largest section up on top of the boat, but still like my set up shown below still pretty tough to do, when needed periodically over an extended cruise on the water.
The 2011 model shown in my photo rode as shown to Alaska & back on our 2010 SE Alaska cruise & weighs 100 lbs with the motor removed, the section Jody has on the boat top, I believe to be 80 lbs. I switched to the same Kaboat as Jody & find it much easier than the Mokai to take off & on the boat top, but the Mokai is a much more stable & safer tow. In SE Alaska I’ve towed the Mokai for about 7000 miles over a 4 cruise period of 9 months total encountering some fairly rough sea conditions. It towed amazingly well & made for a very quick access to shore or other travels from the CD22. There is nothing quite like the experience of exploring remote places with the combination of it & a CD22, but as Bob says towing does add additional risk. Also as Jody said, the jet intake has a tendency to plug when least wanted. I’ve spent many trips to shore, unplugging while trying to keep a close watch out for an inquisitive bear. I was able to mostly solve that problem with a purchased kit, that allowed the screen to be cleaned on the go.
I switched from the Mokai to the Kaboat with a 6 hp Suzuki for several reasons with none of them being I was bored with or didn’t like the Mokai. The main reason being Jo-Lee & I together could only comfortably use it for a short time period. Others are, I pushed my luck to far using it to explore up rivers with some very close calls with the fun & excitement of it overruling my better judgement & the additional risk of towing in rough seas & narrow tidal areas, where a towing rope in the prop could be disastrous.
The Kaboat is much easier to bring along when towing the boat to a cruise destination & get off & on the boat roof when on the water & more comfortable with a twosome to spend extended time on, while exploring or wildlife watching from some remote bay or inlet, but bottom line & if crusing by myself in SE Alaska, it would still be worth the risk to have the Mokai, especially with the new 9.5 hp model that can be broke down into three separate units. If I was to switch back to a Mokai I would use its ability to separate into manageable pieces for use in transporting on the road with full time towing while on the water.
