katkt
- Joined
- May 27, 2004
- Messages
- 243
- Reaction score
- 0
- C Dory Year
- 2003
- C Dory Model
- 24 Tomcat
- Vessel Name
- Katie Kat
The stove was signed out of the factory in 02. It's the model 125DU.
Lack of use is probably going to be a big factor here.
The stove worked properly when we first got the boat(fall 03).
I believe it worked well in 06 or 07? Also, I switched to Klean Heat at that time. The diesel fuel was getting old, and the consensus at the time was Klean Heat was a good stuff.
Last winter when I tried to use the stove, It'd start up, the red light would come on for about five minutes or so and then it'd shut down and the light would go to blinking. Smoke out of the exhaust, Fuel smell in the cabin.
Fast forward to the here and now.
I perused the forum, and took the glow plug out and shined it up per one of the threads and some info in the Library.
I added some alcohol to the fuel because I could hear it popping instead of burning steady. Didn't seem to make much difference.
I changed the fuel out for an unopened and sealed container I had(purchased in 06 or 07), and it seems to be burning better, but still pops...... some.....ever so often.
The boat is on the trailer, with the shore power plugged in, and I'm able to maintain about 12.8 volts on the gauges I have when the stove is turmed on.
When I turn the stove on, with the lid up so I can hear, I hear the motor(pump?) running.........there is also a rhythmic 4/4 soft thump in the back ground.
This continues for about three minutes, the stove strats to get hot, and the red light comes on and stays lit......seems to me, the rhythymic beat in the back ground picks up to about a 3/4 when the red light is on.
I can still hear what sounds like the the fire going out and relighting, although its not as bad as before when I first started. The red light still goes to blinking after about 5 minutes, which I gather is the high heat kicking the pump off.
When the fire is burning well, it sounds abit like an itty bitty gas water heater. Has a steady flame sound....or seems to, maybe I'm nuts? Or deaf? Or both?
Questions,
1.Is the sound I hear, the fire going out and relighting?
2.Is the fact that the stove isn't burning steady ....the popping sound.....the reason the the high heat kicks the stove off and makes the red light blink? Is there some sort of thermal couple, that cuts the power to the glow plug when the fire is going properly, and the heat reaches a certain temp?
3.The instructions say not to cycle the stove to many times, but to figure out what the problem is. Is it okay, to cycle the stove a half dozen or more times to get good fuel to the burner? I would guess that would be when the popping sound stops?
4.Do I need to hook the muffs to one of the motors, and start it, to supply more voltage?
5. Should I go back to the #2 diesel?
6. Should I go to the store and get some brandy new Klean Heat, even though the other container still had the factory seal?
..........any and all suggestions are welcomed and encouraged. Thanks for the help.
Gordon
Questions,
Gordon
