Well-known member
- Joined
- Nov 7, 2003
- Messages
- 7,984
- Reaction score
- 26
- C Dory Year
- 1984
- C Dory Model
- 27 Cruiser
- Hull Identification Number
- wn something
- Vessel Name
- to be decided later
As many of you know I had a deck installed on my 05 22 cruiser. This was a molded deck I got from the factory. I had Lake union Searay do the install. I did this to have my 05 match the raised floor of the new boats coming from the factory. I really do like the deck and it allows my feet to stay dry while I fish,crab,shrimp,etc.
While I like the deck I was not always happy with the install. The floor flexed at the cabin wall and the joint was covered with a badly applied caulking of I think 4200. Well today I finally found the time to remove the caulking and expose the joint. What I found was a gap between the rear cabin wall and the new floor that was partly filled with glass resin ( I think) but was not even with the deck. The glass that connected the wall and the deck was a 1/4 inch shy of being even with the deck. The 1/4 inch space was filled with calking. The glass was also cracked across most of the width of the floor, thus allowing the flex that I was worried about. I hope I am making this clear.
So after cleaning out all the caulking and sanding the edges I mixed up some West marine Structural filler. Now this stuff is full of glass fibers. Looks like a lion throw up a hair ball in a can and they closed the lid before it could run away. I back filled the gap with the filler to just shy of even with the deck and waited for it to harden. Which it did in short order. This stuff really sets up fast. It bonded the crack and floor to the cab so well there is not longer any flex in the floor at all.
So now I am ready to top the gap off with a bead of 5200 fast cure and shape it like I would a bath tub caulking. But then I got to thinking about how well the structural filler did and it being sand able. So my question is can I color this stuff to match my deck or can I cover it with gel coat and do any of you think that the gel coat would last. i would not have thought of it this way but after seeing all the flex go away I got to thinking and that can be a hazard. So any advice???
