Active member
Ok, I know the single vs. twin, single with kicker, argument has been debated and run into the ground many times. That being said, I'd like to hear from others using their boats to run 6-10 miles offshore, and how many are doing so single screw with no kicker. At this time, I have a single 115 hp EFI merc on my 2007 CD-22 Cruiser. Outboard is a 2007 also. I use to own a 1988 Searay 268 Sundancer, single screw with the Merc 454. I had no problems or concerns running that distance offshore, but I was also comfortable with maintaining that car-like IO. I don't have that comfortable knowledge of the outboard, but I believe the modern 4 stroke EFI's are pretty dependable. And I am mechanically inclined... But again, just don't have the experienced confidence with outboards yet. SOooo, without getting the usual conversation of two being better than one, what has been the dependability of the newer outboards, and what kinds of problems could crop up on them that one with mechanical abilities could reasonably repair and limp in on, or that would shut it down completely with no hope for repair on the water? I had been thinking about getting a kicker, but really don't want the added weight or expense if it's not necessary. I do carry an anchor with about 150' of line and a sea drogue/anchor, along with a spare prop and a tool kit. My other question is, if I do end up getting a kicker, how do most have it set up for steering and throttle? (I assume most have steering linked to main, but what about throttle?)
