fidalgoisland
The drain plug on my 2004 22 Cruiser has developed a very slow leak. It was installed from the inside. I leave my boat in the water most of the time and would like to know if there is a way to change it without pulling clear out. I did a search and found a discussion and someone mentioned that if you take it out and go up on plane...water won't come in when you pull the plug so you can change it. I don't want to do anything risky so though I would ask here. Thanks in advance for your help.
Dennis
Dennis
