CC Rider
Member
- Joined
- Nov 18, 2013
- Messages
- 167
- Reaction score
- 0
- C Dory Year
- 2006
- C Dory Model
- 23 Venture
- Hull Identification Number
- GXK23015K606
- Vessel Name
- CC Rider
My Cape Cruiser 23' came with a Group 24 battery on each of the 115HP Yamaha main, and on the 8HP Yamaha kicker (has electric start/tilt). There is a A-B-Both switch connected between the 2 batteries. These are located in the 23's horizonatal locker at the rear of the cockpit.
Everything on the boat is connected to the main's battery except a couple of Scotty downriggers which are connected to the kicker battery. There is a Guest 2-bank 10A charger on board.
Needless to say, I need to change this arrangement.
I want to install a couple of house batteries and re-arrange the sources for all the loads on board, especially the fridge, Wallas, and cabin lights. My thought is to put a set of new batteries under the V-berth platform (haven't cut the access holes yet, but will need to do this mod as well). I don't want to put any more weight on the already heavy stern.
Questions:
1. What type of batteries for the house bank? My understanding is they must be AGM or Gel due to gassing in the enclosed space. I take it that regulated-valve flooded batteries are not a good idea and AGM or Gel are the only choices? I would like to get about 200Ah of capacity. AGM's are sure pricey!!
2. I have purchased a new Mastervolt 12-25/3 charger which I intend to install soon. I am a little surprised to learn that one can't set battery types for individual legs of the charger. It's a global setting across the entire charger. I think that other chargers are like this as well. So, this brings up the question of what to set the Mastervolt battery type to. Likely AGM, even though there will be the Group 24's on the other charger legs.
3. I would like to charge the new bank via the main engine as well. My thinking is to install an ACR between the main's start battery and the new bank. Any harm in combining the start and possible AGM bank via the ACR?
Any advice appreciated...
Chris
Questions:
Chris
