New Bilge Pump from Attwood
crowleykirk
If you're looking to install a new bilge pump this might be worth checking out.
From Boat Test.
Attwood Corporation, which makes a variety of accessories for the marine industry, has unveiled the new Sahara Mk2 automatic bilge pump. The company says the pump is the only one on the market that eliminates air-locks thanks to its patented X-Air impeller. It ejects trapped air so the pump won’t run dry and burn out the motor.
Key Features
To make the Sahara Mk2 easier to install, Attwood uses external mounting feet instead of having to drive screws through the bottom of the basket. The new design eliminates the need to separate the two for installation. The outlet is also on the basket and not the housing so the latter doesn’t need to be removed for installation or maintenance. The pump also comes with straight and 90-degree outlets for more flexibility of installation.
