flapbreaker
- Joined
- Jan 26, 2005
- Messages
- 878
- Reaction score
- 0
- C Dory Year
- 2006
- C Dory Model
- 22 Cruiser
- Vessel Name
- Playin' Hooky
CatyMae n Steve":3m592p62 said:I'm going to add to your thought process. We have the 90 and a kicker -- kicker mounted on the starboard side...normally they put both batteries in the starboard lazarette...we listed for several months until we made a change and put the batteries in the port lazarette...some cabling issues that the dealer took care of quite nicely (the switches for the batteries remain in the starboard lazarette, so we store only lightweight items there)...and now we don't list -- I don't know if the configuration of a kicker on the port side is possible, but you might want to give that consideration in order to not have to move the batteries so's not to list. We put a leather pad on the boat where the kicker comes up in the resting position against the stern...works out great so neither the boat nor the kicker get scuff marks. We like controlling the kicker from the helm, so we've attached a bar to the main motor...and a call out to the other person if we want the speed adjusted. This has been a good selection for us, because our main (only time we cruise is to get to fishing grounds usually...) use of the boat is for fishing.
Caty
PS...gone fishin tomorrow... :thup
My kicker is on the starboard side and I have a battery in each lazerett and no listing. I think you just have to plan your fuel and water load to achieve this. If your not going to keep the fuel tanks full then just make sure the port tank has more and that the water tank is full.
Steve,
You might want to check out getting a trollmaster for throttle control on the kicker. It's relatively cheap but would make adjusting the idle on the kicker easier. You can even mount the throttle control up at the helm. http://www.troll-masterpro.com/
