Active member
- Joined
- Nov 7, 2003
- Messages
- 7,976
- Reaction score
- 15
- C Dory Year
- 1984
- C Dory Model
- 27 Cruiser
- Hull Identification Number
- wn something
- Vessel Name
- to be decided later
I think that one of the better improvements in hull design of the cc23 over the 22 was in the width of the stern. the 22 ,as you move from the bow to the stern, get widest about half to three quarters of the way down the hull then thins up a bit at the stern. It falls into its own hole in the water. The cc23 is widest at about the same point BUT stays that wide for the remainder of the hull length. this provides more lift area and does not allow the hull to fall into is own hole. I believe that this is the reason for the better fuel number with a heavier boat. It is the most common design, regardless of rake and bow angle , of medium size power boat built. It also allows for a larger rear deck. Just opinion from owning a 22 ( 1500 hours in 5 years) and fishing 30 times out of another persons 23 last year.
I have thought at some point having a improved copy of my 27 built out of aluminum. The major change in the hull after giving it some v would be to widen the stern to match the wide point in the hull. Must likely make the hull wider by a foot too.
