C-Pup16 in Los Angeles
I have a 2003 16 ft CD cruiser that I usually keep garaged. When at sea or when washing it on its trailer however, spray water will pool inside the boat until I dry it out.
Some of the rivets attaching the seat platform and side wall to the floor have sheared off over the years. It occurred to me that this creates a hole for passage of water into the hull and balsa core… not good.
What is your suggested remedy?
1) Leave it and shoot silicon into the former rivet area;
2) Shoot silicon in the hole then screw-in a shallow stainless screw;
3) re-revet the holes;
How much “meat” is there to the bottom hull for #2 solution, screws? So you have a suggestion on screw size?
Is re-riveting possible? What kind of business might do that in Los Angeles, CA?
Thank you and be well.
Keith Dager
C-PUP16 in Los Angeles, CA
Keith Dager
