Chris,
Experimenting is probably the easiest way. Start with what you have, run the boat up to full throttle and see what the rpm's are. Compare your rpm with the maximum full throttle range for your motor. If you are under that range, you need a prop with a lower pitch. If over then more pitch would help.
I would start with a 13 pitch and see what you get. You probably want to have more than one propeller with you on your trip. Since you have a 15 pitch, see if the dealer will loan you a lower pitched prop for trials.
Do you know how heavy your boat is? You could take it to a truck scale and weigh it. Add the weight of fuel and water and anything which is not already aboard. If the boat is over 5,000lbs, not counting the trailer, you probably need about a 13 pitch. That may be the lowest pitch available, check the prop listings.
Larry H
