SEA3PO
- Joined
- Nov 2, 2003
- Messages
- 1,835
- Reaction score
- 1
- C Dory Year
- 2003
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- CDO22132D303
- Vessel Name
- SEA3PO
I have a Dickerson propane stove aboard, and I normally use a 1 gallon propane tank...largest tank I could install...but have decided to add a Dickerson Fireplace Heater and needed additional propane for longer trips.
So I bought one of those Keen composite propane 2.5 gallon tanks at last years boat show...and made a extended bottom to the lazarette...I used West Systems Epoxy over a 5 gallon paint bucket for the mold..then epoxied it to the bottom of the lazarette..then glassed from the top down to finish installing it... worked out great...and easily holds the 2.5 gallon tank... for short trips I will still use the one gallon tank... The lazarette is air tight and vents to the outside so it is perfect for the job...made good use of wasted space above the fuel tank.. often wondered why C-Dory made that space so small with all that extra room under it..
Now all I need do is sand it some and give it a finish coat...and enjoy..
Check out the pictures in my Photo log...
Joel
SEA3PO
Joel
SEA3PO
