henrym
- Joined
- Dec 31, 2007
- Messages
- 28
- Reaction score
- 0
- C Dory Year
- 2008
- C Dory Model
- R-25 Tug
- Hull Identification Number
- #75
- Vessel Name
- Little Toot
The R-25 overhead hatch riser arm adjustment knob's stainless steel screw
is cupped and as a result it chews up the soft aluminum rod in the riser
arm. I ground down the end of the screw so it was flat and then beveled it
slightly while polishing it on a 600 grit grinding wheel. Problem solved...
