Winyah
- Joined
- Nov 12, 2003
- Messages
- 18
- Reaction score
- 0
- C Dory Year
- 2000
- C Dory Model
- 22 Cruiser
- Vessel Name
- Winyah
I've used the S1000 for trolling for a couple of months now and really like it. The standard settings from the initial setup did not work well at trolling speeds on Lake Superior (2 mph). I had to manually mess with the settings so it did not overwork at slow speeds. If I want to use it at cruising speeds, I change the "response" settings. The unit will maintain a heading at 2 mph and less, but if you slow down too much and pull the throttle back to the positive stop just before neutral, the unit will lose its fix and shut down.
Steering from the cockpit at trolling speed with the remote is really nice--allows me to spend more time with the co-pilot while she's watching the rods.
I wrapped insulating foam around the pump to cut down on the noise.
There is a learning curve and some adjustments to be made depending on your needs, but it has worked out well for me.
Gary on "Winyah"
Gary on "Winyah"
